Some late C4 and Rosalie had 40 rims (it means 40cm of diameter)(instead of 45.). This size was still used in the 50's on many french cars, but was then called 400 (for 400mm). So you can find this 400 tires easily in vintage tires shops.
BUT these 40 rims were only available in 5 holes (I think...)
Anyway 13/14 x 45 are available too in most vintage tires shops...:
https://www.classictyrestore.com/fr/bibendum/933-avon-supreme-1314x45-86n.html
I myself run 16' tires on 40 rims. It's approximatively the same difference of diameter than your 18' on 45 rims. As long as I center the tires properly on the rims when I inflate them, I find them round enough..!
